- Joined
- 2 Feb 2010
- Messages
- 10
- Reaction score
- 0
- Country
I have a baxi 80e combi about 7 years old.The heating works fine but hot water not.When i turn on the h/w tap it runs hot then cold,hot then cold . The burner activates for about 20-30 secs then goes out,it does not modulate.The diverter valve was checked and seams to be operating as it should.Now and again i have to top up the heating circuit as the pressure drops slightly. Had the same problem around 5 year ago and the dhw plate heat exchanger was changed and gas pressure adjusted.has anyone got any ideas what is wrong?
