Yes combustion door seals shot leading to overheat stat on fan doing its job.Replace door complete with seals and electrodes and kill two turds with one stone.Repeat ad infernitum No a.p.s on this boiler...
Hi
I just answered my own question .Yes i am thick !!.
Your talking about the actual combustion door the one you see the flame thru .With the other post of is there any insultion on the outer door protecting the sensors i thought we were still on about that door .God i see how it works now if the combustion door seal has shrunk etc it fills the rest of the sealed boiler with hot air and triggers the thermo on the fan which then cuts out the boiler .
God i must have been half a sleep yesterday .
Can i replace the seal then ,whats it made of nothing dangerous like asbestos ? Or is it easier for the whole door to be bought and repalced altho i should think thats expensive .
the seals can bought on their own but i wouldnt advise you to do it if your not competent....i can also bet your burner is cracked so get someone out to do it properly
