Baxi Barcelona - ignition lock out
Have set electrode gap (& cleaned) whenever I stand in front of it .. it fires up on first spark ... I know it can have multiple attempts.
I'll disconnect the water trap connection for a while and see if that makes a difference.
I noticed that it is about 3/4 full. ... both sides
Since I removed and cleaned it fully ... left hand side wasd empty and right hand side 3/4 full.
I assume that is what it should look like in service?
My mate has the exact same problem , if it anit the above what else could it be ?
Arf
failing that i just change the pump and see what happens, if it doesnt work i put the old one back on.
but surlely thats too easy to do :LOL: .
so has anyone checked the operation of the flowswitch on this boiler.... its been the solution to this very fault before. of course being a 'parts changer' what would i know. :LOL:
You won't get a maintenance contract on a Barcelona.
Anyone who's been in this business a few years knows what a heap they are. Any repairs will be shortlived.
BG will take it on.
actually most issues are down to poor servicing and a lack of logical faultfinding.
i dont believe this is neccesarily ign lockout. i had a similar issue with inoperation last year. after various people had replaced all stats seals sensors electrodes condense tarps pcbs et al i was able to observe the flowswitch going open circuit during the operation of thr boiler and giving the flashing lockout light. 1 replaced flowswitch later (surprisingly easy for once :LOL: ) and problem solved.
baxipot , i`ve just spoke with my mate , his lockout is a flashing red . once a second
whats that then , please . arf
he`s changed , flue stat , over heat stat and temp sensor . anymore ideas .
I said change boiler :p
