I have a constant overflow coming from header tank, the water is hot. As a result of advice from several engineers I just changed the cylinder fearing the coil had broken causing cold and hot water to mix. This is obviously not the case now as water is still leaking.
I have a baxi bermuda sp3, only 5 years old. I have hot water and the heating is working fine. Bled all radiators after flushing the system.
Any ideas would be most appreciated as this is giving me sleepless nights just thinking about it.
Cheers
Cheers
