Steamers don't need ventilation as far as I know,
Some still need compartment vents.
A bbu in a compartment? Never stop learning in this business.
Ah, I thought it was a bit funny.
Mind you, a steamer that needs compartment ventilation can't be that good.
CDI does not need compartment ventilation.
Those minimum dimensions are 5 mm to the side, and 20 mm to the front, and compulsory anyway. It doesn't say in the manual that it needs ventilation if the box is smaller, it says that you MUST HAVE them as a minimum to allow servicing, not for cooling. For the CDI that is, didn't check all the other manuals...It does not need a vent in compartment PROVIDING minimum dimensions are met , same as a lot of boilers...
....which means if minimum distances are not then compartment ventilation then applies.
It could so happen that somebody has done this, but it would be a contravention of the M.I., not requiring ventilation, but alteration.These clearances are for installation and servicing it could so happen that a cupboard smaller is then put around the boiler that is removeable for servicing in which case compartment vents would be req
Maybe your manual is a different version from the one I have got, but mine definitely does not read:"If you were to ignore the compulsory minimum distances, don't forget to drill some holes for ventilation."Yes its nit picking but still a case of compartment vents being req for a steamer
