I have a Baxi 80Eco boiler which has worked perfectly for 3 years. I have installed a towel rad a few month ago with no problems. However, I recently changed an existing rad for a different shape one (only marginally bigger) in a bedroom.
After I refilled the system and bleed all the rads there is a noise coming from the boiler..(pump i think). It is a vibration noise which comes and goes and can be high pitched. The noise happens on the central heating and on the hot water.
I have bleed a lot from the centre screw of the pump (gunfoss 15-50 single speed). This stops it only on the cental heating system for the day. It is then back the next day and never goes on the hot water.
All of the rads are heating up ok and have bleed them loads!....any ideas...please help!
mike
mike
