Are you certain its the plate blocked again ? Run a hot tap and check the heating flow pipe (left hand side). Diverter cartridge on these don't like dirt either.
Remove a radiator, take it outside and flush it with garden hose wack it a few times on the base rib to dislodge settled sediment and flush till water cleanish. Refit radiator but do not allow water to enter
Repeat same process until you have cleaned all radiators. Now pressurise and purge radiators. If you are up to it, instal mag filter
Doubt your system was flushed: emptied to instal new boiler, flushed unlikely (else you would not be clearing the plate HE so regularly. Wonder if the gas line is sized correctly
It just keeps getting better. The wife just ran a bath and the boiler started dripping quite quickly. I traced the leak back to water coming out through the air vent on the top of the boiler.
Overheating does that sometimes (steam escaping from auto air vent). At other times sediment/ muck/ first in system causes the air vent not to close when air has self purged
Yeah. I suspect the latter. I turned off the system and, cold, it is still leaking. Stuck open I guess. Is this something I can take off and clean or does it need to be replaced?
(Actually I can't find a spare for sale online - there seem to be replacements about for the pump vent but not this one).
I would still look at the filter option, it not expensive, easy to install (if you removed the heat exchanger and cleaned it, you would do this a piece of p!ss) And its a lot easier to clean out the filter every now and then, instead of cleaning out the plate heat exchanger every 6 months. It would also reduce the chance of dirt effecting other componants eg pump, auto air vent
Just to add to this, you could also put chemical cleaner into system as well as the filter to help remove the sludge/dirt. And then empty system and then refill and add inhibitor.
