I wonder if someone could please help me diagnose the problems with my Baxi 80e Combi boiler?
It doesn't seem to working correctly and it's pretty annoying!
The problems are these:
1. DHW gets hot, then goes stone cold, then gets hot again...makes for an "exciting" shower experience!!
The boiler ignites when the DHW is on, temperature climbs to max (80 degrees) and then switches off. When the 80 degree lamp goes out, it re-ignites. Makes no difference what I set the temperature control to, this is the pattern.
2. CH doesn't seem to heat up thoroughly.
When I call for CH, the boiler ignites and brings the temperature to that set on the temperature control but then goes off. Temperature drops to nothing but it doesn't re-ignite.
There are never any fault indications on the front panel lamps for either DHW or CH problems.
Last year I had the diverter valve and DHW flow valve diaphragm replaced.
Any suggestions on what might be wrong, or additional observations I need to make to help figure it out?
Thanks in advance,
dK
Thanks in advance,
dK
