- Joined
- 2 Nov 2015
- Messages
- 3
- Reaction score
- 0
- Country
Evening all
Recently moved house. New house has a Baxicombi 80e
I had a problem with the hot water, the flow rate through the shower wasn't sufficient to trigger the hot water microswitch, unless I ran the washbasin tap first.
Believed it to be the DHW Diaphragm, so replaced it. Genuine Baxi parts, not cheap internet alternatives (just not worth the bother and time to do it on the cheap).
At the same time, replaced a leaking auto-air vent on the pump body.
All seemed to go well, apart from now I don't get any hot water, only luke warm ~40 degrees on panel front.
This is the older Baxiboiler with a hydraulic 3-way valve, not a motorised valve, so thought that perhaps the Diaphragm on the Central Heating diverter was outof balance with thenew DHWDiaphragm, so have replaced the Central Heating Diverter Diaphragm also.
Unfortunately still no Hot water.
Nothing apparently wrong on the front panel, no flashings lights. The DHW & CH Pins activate the microswitches when expected, both for DHW demand, only ch for CH demand. CH Pins retract after about 25 seconds from demand stopping, DHW immediately.
I have added sludge remover, flushed the system, re-pressurised the system..
Short of replacing the whole Diverter valve, does anyone else have any suggestions / ideas as to what may be wrong ?
Many thanks for your replies.
Maurice
Maurice
