I have same problem with may BAXI Luna HT 1.240. After changing electrodes and cleaning every possible part boiler not started to work and error code was E133. In installer guide I found infor abou correct gaps between burner and ionisation electrode and ignition electrode. After setting correct gaps boiler started to work.
