Baxi DuoTec Compact 24GA E133
12 Nov 2018
Armenia
Hi dears.
I am from Armenia and i about 5 years have Baxi DuoTec Compact 24GA.
And about 3 days i have error E133
Our specialists check gas supply pressure, flames sensing electrode and Ionization electrode and cleaned both, they cleaned burner too, condensate cup is ok not full, Gas filter is clean.
I catch this error daily 9-10 times in other cases Boiler works normally.
And i see when it trying to do flame and it unsuccessful in that times in Gas meter numbers not switching it means it is not trying to receive gas for flame and i hear high volume of Ventilator which you can listen in video..
Auto calibration tried 3 times not helps.
Our specialist cant't help me, pls any suggestion and sorry for my bad English.
Here is video with issue:
Error log:
Е133
=18
000
03
F15 Sometmes F01
36C
Pls help!!
Now it fully not starting always E133 in hot water too
your boiler is not getting gas either because of the supply or because of an integral part of the boiler, sorry but the site rules prevent me from advising anything further as it involves gas safety
The technicans now going to change Gas Valve. Any else sugestion? Pls help me!!
That sounds like the most possible cause but can be other things
?? Pls tell me what to try if gas valve change not worked. Try to change flames sensing electrode and Ionization electrod?
Gas valve didn't solve issue.
Any suggestions plsss
After again cleaning flames sensing electrode it begin works with sometimes error E133 tomorrow they will bring new flames sensing electrode and change and see what will be happen.
And they say in other case it will be all electronic micro scheme (plata). Is it possible?
You'll probably need Baxi...these were terrible boilers. AFAIR the gas valve change required a software update too.
I didn't ask here what to buy. I have boiler and now have issue and will be good to receive suggestions.
