N
namsag
you may find they have an upper age limit on the boiler of about 8 years not 100% on that though
I shall go for the quick fix until the summer and then get some quotes for a new Baxi Solo 30 HE
assume the boiler drives a pump over run? But is the pimp connected to the boiler?
I would have expected anyone replacing the heat exchanger to have checked that ???
a solo 2 pf does this aint the new he version it 15 yr oldassume the boiler drives a pump over run? But is the pimp connected to the boiler?
baxi solo doesn't require pump overrun. same as the he model. viessmann compact also don't require one. if looking at a heat only boiler.
