Baxi Solo 2 PF
Status
Not open for further replies.
Get someone to check the fan and the air pressure switch hoses.
Those who cackle loudest on here don't want you to know this, but you are allowed to work on your own boiler, not for anyone else even as a freebie, if you are not registered.
As they say, a good man should be able to find and fix the fault.
Can anyone help?
I have a baxi solo 2 boiler that is causing me some grief, when you go to fire the boiler up, all you get is the boiler on & the fan on but does not go any further, but a tap on the side off the boiler and it fires up no problem, so I have had the front off and tapped everything. When i tapped the air pressure switch it fires up fine. It only goes into fire sequence when i tap the air pressure switch. I have only just had this air pressure switch fitted any ideas it seems faulty to me or does anyone know of a common fault?
Are you getting a spark and any sort of pilot?
Status
