These boards may be re-conditioned, but do these firms doing this actually have a boiler there to try them out in the real world?
has anybody told this guy to check flow switch!! first.if you have 1 green light signal from timer there just pump needs proving for fan to start
Thanks for the replies guys, especially the tip about bleeding the radiators....I new I was over analysing the problem! applied 230v to the fan, all o.k, checked resistance across overheat stat and returned 1.5 Ohms, if you're correct Tony it looks like you go straight to the top of the class and I stand in the corner wearing a big pointy hat with "D" written on it. Will replace stat and see if it is this.. lookin like it may be a winner though.
Cheers
Be careful when working with 'live' electrics
check to see if you have 240v at the fans plug on the pcb.
you say you have checked the stats, have you checked the thermostat sensor
Cheers
Its the only thing that hasn't been replaced
I said to replace it in my very first post.
