Problem started with fan seizing. Corgi man replaced fan enabled boiler to start but after 3-4 minutes it shut down then immediately restarted (have read other posts on this subject). It continued to do that. Replaced PCB, no improvement - worse wouldn't even keep running on room stat. replaced gas valve and solenoid - no better, reset fan gasket with silicon sealant - no better, dismantled and cleaned pilot and main burners - no better, replaced air pressure switch and tubes - no better. Re-installed original PCB, does at least keep running on room stat. Replaced thermostat and overheat thermostat - no improvement. Exchanged first new PCB as faulty, installed the replacement no different from original PCB.
My CORGI engineer has many years of experience and I am a professional engineer, FIMechE and we are both baffled.
