Finally working OK
Your boiler/flue is designed to run with a restrictor fitted as per the Manufacturers Instructions.
Flue gas sample OK?
In particular check the CO readings.
Fitting the correct Air Pressure Switch part No. 5111609, which was designed precisely for this phenomenon, should be the answer.
