not a problemMy mistake about Baxi instant
dont understand that then? Baxi 105's have the 22mm by-pass pipe with the little pigs tail sensing pipe on it.! So how would there be 2 differant divertor setups?? For 2 differant Baxi boilers?? Or actually for the 105's?you get two different diverter setups depending on whether the boiler has an internal by-pass or not, they are not interchangeable, they will fit but wont work if you have the wrong one
That is not the by-pass that is the sensing tubes that operate the DHW Diaphragm, those two pipes contain only cold mains water, the by pass is elsewhereBaxi 105's have the 22mm by-pass pipe with the little pigs tail sensing pipe on
To see if you still have a supply of cold water crossing over to the hot side from the shower cartridge.If the cw inlet to boiler is shut, what do I open hw tap for?
