I have a bay window made from wood in good condition.
The bedroom section is double glazed in the thinner type double glazing. Maybe 12mm thick.
This bay creates a lot of condensation. So much that it runs off the cill internally and down the wall.
It needs wiping a lot and so black debris does accumulate around the panes.
I have fitted 3 trickle vents on each side of the bay, but I still have this issue. The house is well insulated and I have a C rating on my EPC.
I use a dehumidifier to help lower the moisture content in the room.
Got the same issue below in the lounge but it’s not as bad even though that window is bigger.
Plus this window has 50% of it in single glazing.
Any ideas on what I could do with these windows. Is it a case of only a pvc replacement will stop the problem?
