Bay window replacement
You would use acrow props to support the barrel maybe even 2 long ones to support the roof on the top bay.
Pvc windows would need to be fully reinforced with steel and the round baypoles would need to be jacked up to take the slack and weight, this is like a little gizmo thing shown here...
https://www.google.co.uk/search?q=b...SK0AWK24D4Ag&ved=0CAgQ_AUoAQ&biw=1024&bih=455
The baypole would need to be sunk through the pvc cill of the window so that it sits on the brickwork not a hollow pvc section cill, this applies to the top one also
Ok thanks for info, i will look into it all. I do use acros to prop joists when i have taken down internal walls to replace with a steel so fairly competent with all that work. Prob look at getting someone to do it though.
As for renovation i will certainly be keeping all original features apart from the glass as it will be too expensive to incorporate this in a d/g set up.
Doors will stay and on both houses i have uncovered all original internal doors and staircase covered in chip board.
Maybe look into encapsulating just the small top sections with leads. I seemed to remember that it did not add a huge amount to the overall cost when I was looking to do it.
There are quite a few companies who do it now. Once based in manchester seem to have a good presence but I am sure there are a few around yorkshire too. If you search for local leaded light repairers, they will probably have further contacts.
I think it just retains a bit of window character. You may be suprised at how nice they will look once properly cleaned and in situ.
I dont know how much reusing the old glass in a new unit would cost but you could just get it replicated. I had some custom lead and color designs done to some units like that recently and it cost an extra £50 per unit
