firstly, have you carried out any tests on the circuit, ring circuit continuity, R1+R2, Insulation resistance and Earth Loop Impedence, Along with prospective short circuit current and prospective fault current to make sure they all comply with the limitations laid down by BS7671? I suspect not, therefore, how do you know if the circuit is safe now?? , or that it was even safe before, if you are a qualified electrician, you can produce your own EIC, the LABC may require you to prove your competence by asking to see your qualifications, most will not accept anything less than C&G 2391 (Inspection & Testing).
I guess what I am trying to say is there is a lot more to wiring or altering a ring main than doing the work then switching it on to see if it works without any unwanted sparks, a ring can also have some quite serious faults and still work, untill you apply a larger load, hence the testing being so important. Part P was brought about for a reason, and even a lot of full time sparks don't like it, but it was done to stop DIYers, Builders, Kitchen fitters and the like from carrying out potentially dangerous work!
