I assume your pics are showing that the outer skin is visible inside -a cold spot for condensation? So windows should be fitted flush with the inside of the outer skin?
Used to be in the good old days, but times have changed and thermal bridging means a change of position.So windows should be fitted flush with the inside of the outer skin?
That's why you put plates across the cavity at the bottom and pack the windows of those. May be a small thermal bridge and some people build ply boxes and all sorts, but you can't float them off sky hooks!Straps will not support any weight
What make of windows are you using? Most do a 225cill (some even do a 250mm). Straps can also be purchased specifically for your make of windows that clip in.
Thats a canny argument at best. All frames are in the shade at night time, and it would not trump having the frame too far forward.Setting windows back too far creates it's own set of problems due to the micro climate formed by the shading of the frame
Victorian sash windows that were fitted behind the outside brick skin, have lasted so long due to their protection from weather.
So setting back windows from the outer face is a good thing generally.
