bdr91 wiring advice
16 Oct 2014
Hertfordshire
Hi all
I had cleaned up the boiler wiring and installed a honeywell wiring centre to replace a messily wired 10way junction box
And as it is all clearly labelled it made life easier for myself when i bought a cheap drayton mistat wireless thermostat. just had to wire 1 and 3 between the 2
Ive finally gone for the big upgrade and invested in the honeywell evohome
Im a bit lost on wiring it in as the labelling on the bdr91 doesn't match to the wiring centre as other than the live neutral its A and B
If i wire as a room stat which was my first idea because I'm waiting for the hot water kit to arrive (another week) so still need my current programmer for turning on hot water , would A go to 1 and B to 3 on the wiring centre ?
And should i be wiring the bdr91 into the programmer section once i no longer require the old programer ?
Don't really want to change back to a 10way junction box but as all the wiring guides show it that way ill do that if its a issue
Lastly how would you normally power the bdr91 for the live and neutral ,through a separate 3map isolator ?
Want to do it right and this seems the best place to ask
Many thanks
Leigh
Depends on your system and boiler, but my crystal ball needs a new battery!
If i wire as a room stat ... would A go to 1 and B to 3 on the wiring centre ?
Yes
And should i be wiring the bdr91 into the programmer section once i no longer require the old programmer?
What is included in the hot water kit?
Lastly how would you normally power the bdr91 for the live and neutral ,through a separate 3map isolator?
No. The BDR91 should be powered from the same isolator as the wiring centre. You could power it direct from any L and N terminals in the wiring centre, except for the pump, i.e Mains, Boiler and Programmer.
Found the answer to my own question!
I would wire both BDR91's , i.e. the CH and HW, into the respective thermostat terminals in the wiring centre.
Room stat BDR91- as in previous post
Cylinder stat BDR91 - A to C; B to 1; C to 2.
Insert links on the Wiring Centre Programmer block between L & CH ON, and between L & HW ON.
Many thanks for taking the time to reply
Ill give it a go on sunday , but with the above info I'm pretty confident it should be straightforward
