loads of skim beads, accidentally left them outside uncovered all winter. They’re dulled but not rusty. Safe to use? Or better bin them incase they rust in years to come? Cheers.
True, just that there’s loads of them and I’d rather not throw them away. You’re probably right though, not worth the risk. Only times I’ve ever seen beads rusted in situ is externally or in damp areas internally.
if they are the galvanised ones, the galvanising weathers away over time. If they have gone dull they have already lost some of the original coating. The original coating was only intended to stop them rusting in the warehouse or on-site while the plaster was wet.
