just tap the "thin, small-headed pin/nail" into the end of the "ply",,, where it suits the inside edge of the window frame you'll work/guide it from,,,,, to get the reveal bonding plaster square.....Running the window-gauge/nail up the window frame is the only thing you need to be careful with......
The 6"x2"x 12mm gauge is only an example...............The flat 2" face of the gauge would face upwards, it would only be the 12mm edge that would touch the plaster........ the nail would be put into the end of the piece of wood, in a measured position, where it would overlap onto the square plastic edge of your window frame as a guide. The sticking out nail, overlapping onto the inside plastic edge of the window frame, will stop the gauge from digging in...You don't need to apply any pressure.... The bead on the reveal corner,, and the nail overlapping onto the guiding edge or your window frame, will allow the gauge to be dragged over the wet plaster reveal, removing any excess, giving you an even coat of plaster, any hollows can be filled in,, then run the gauge over the plaster again, and so on until it is filled out. Put tape over the nail though....You'll find it so easy to do once you understand it. This is where a sketch page would be invaluable..
Roughcaster.
Roughcaster.
o' r' I'd forgotten he is going to chop the rest of the reveal off.
I thought you done well on that one.
I know just what you mean, sometimes it would be easier to drive there and show people than putting it in to words.
would you like to try the six stages ? it just something you know from experience but how can you put that in to words.
Roughcaster.
get DIYnewbee99 to explain the reveal gauge to you, and refresh your memory,,,, he knows all about it now.......
Roughcaster.
