I have A Beko DE3431F dishwasher which when I switch it on to wash it makes noise but doesn't take water in. Have tried switching on and off, resetting etc. but still just makes noise can anyone help? Please
Not familiar with this machine but does it sound like the drain pump running.
Un plug it and tip it backwards a little bit and see if water comes out of the base (or remove the bottom panel/kick plate or the sides and see if water is in the base as the anti flood may have been activated.
