I wonder if anyone can help?
I have Beko dishwasher that has stopped working. I first realised there was an issue when I saw that water was not draining. I removed this and then cleaned filters and dug around the drainage hole and turned back on.
Turned off cycle and found it still wasn't draining and turned back on. This time no water was being pumped and when open a little steam came from the drainage hole; this did not smell electrical so assume hot water as I found warm water when investigating.
Now the machine just hums, any ideas?
At the start I did pull some paper from the filter so assume maybe this has wrapped arounf the impeller?
Regards,
Regards,
