Beko Dishwasher
24 Jan 2007
Gloucestershire
I have a Beko Slimline Dishwasher that is about 3 years old. I turned it on yesterday and it will not fill up with water, but there was a lot of foam in it. the dial is going around a bit, but nothing happens. Any help would be appreciated.
Check water is on & filter is not blocked (Filter in the filling hose)
Is the drain pump running all the time?
Tip it back about 45 degrees and see it water drains out of the base.
I have drained it now and it appears to be working on a couple of cycles, which it would not do before. Many thanks for the top Tips that you have given me.
However, I have tried it again last night and some programs work perfectly, however the one that I normally use (No. 3) fills up with some water which then creates the bubbles, but does not dissolve the tablet and then does nothing. There was water all over the floor this morning. There is obviously something still wrong. Any other help would be really appreciated.
