J
John45
The control panel looks for a particular condition of a wired circuit.
There are two ways to have a default condition.
One is where a circuit is made and so has a specific resistance that can be measured by the control panel. A change in this resistance reading is what indicates a circuit has been tampered with.
So a door contact will have a reed switch where the proximity of the magnet will cause the contact to close and make up the circuit. Therefore either opening the door or cutting the wire will create a resistance change that would indicate an alarm condition.
However you could have a circuit that is always open. ie the magnet keeps the circuit open and the alarm would activate instead if the circuit is made.
That method was the 'old way' of doing things but it was too easy to defeat .
It was a very simplistic way of operation where the alarm was sounded by the contact purely because closing the circuit made a feed for the sounder.
Its how you would make an alarm yourself if geven a battery and a few bits of wire and a speaker.
Pirs however are an always open circuit where activation 'makes' the circuit hence the need for a seperate tamper circuit to detect cutting.
The tamper circuits are always closed also, hence cutting them causes an alarm
