Bell on constantly
is that at the panel, at the bell?
the default in the panel is SAB and the default on the bell is SAB, if one is changed then bell is on continuously, if they are both set to same value it only rings when triggered
what I dont want is you to be sending data backwards and forwards using wintex and not knowing if you have changed some or none of the settings
I have just noticed that BELL ON ARM FAIL was ticked, l remember unticking this a few days ago.
The bell is now silent ,could that be the problem ?
bell on arm fail, isnt the issue.
unlikely its corrupted
can you do this by the keypad?
The issue is I dont know what you have or havent done in wintex and have or havent uploaded to the panel.
wont be the first time I have accidently deleted something to the panel as the wintex profile wasnt uptodate with the latest programing on the panel
okay, you cant see the bell jumper settings?
when you put the orange in bell trigger it triggers bell?
change to scb if thats the case by pressing NO(X) and you should see the keypad option change, then wire in the bell trigger.
should no longer be ringing, then do a bell and strobe test to make sure they are working properly.
