Belling Farmhouse Cooker 90. One oven not working but not element
Before you actually remove it, if you can get access to its wires, it might safe a bit of hassle if you check its resistance at ~ 23/25ohms?
So replaced element, reconnected and set clock and it's working fine. Thanks for all your help.
Thats fantastic.
Just in case I have to do it sometime, how did you change it?, from the rear or from the inside?
Also, for interest only, next time you isolate the cooker and then power it back up, can you see if either of the ovens will come on without resetting the clock.
Element changed from the inside. Really simple, only 6 screws.
I'm not sure what the deal is with the clock. The main oven seemed to work fine either way but the smaller oven didn't work without setting it once power was reconnected. Hopefully I won't have to do it again anytime soon but I'll check if I have to.
