Bending 10m Grey flat twin and earth for showers
20 Jan 2012
Norwich
I've noted the recommended radius for bending 10mm grey flat twin and earth cable the radius does not work with the wire coming out of the wall into a Mira 9.8 Kwh Azora shower following the route recommended by the manufacturer; the cable has to be bent at a small radius to fit into and down the cable channel then up into the terminal connectors.
However, bending the cable to a radius that is required appears not to be detrimental to the structure of the cable; no stress marks seen and seems to work.
Also, bending this 10mm cable around a 90 degree corner is not practical as the bend needs to be a less radius than recommended by electrical standards.
Any ideas please.
