I've built a softwood frame (1300mm wide 350mm deep) in the corner of my bathroom and installed a semi-recessed basin in the worktop and a toilet next to it. I want to build a bathroom unit around the frame to hide the cistern and create a cupboard under the basin. The softwood frame is sized so I need a 500mm fixed panel behind the toilet and 2 x 350mm doors for under the basin. In addition I want to re-do two airing cupboard doors to match.
Hence a need 5 panel doors (4 to be used as doors and 1 as a fixed panel) and lots of lengths of timer which I can use to hang the doors off and then build the rest of the unit around the doors.
My initial thoughts were to get a local joiner to make the panel door frames using 3'' x 1'' and provide me with the other planed timber. 3'' x 1'' would plane down to about 70mm x 20mm I would think. The panel in each door could then be 9mm veneered mdf to match the solid wood which would result in approx 11mm depth to the panel door.
Any ideas on which wood to use to cope with the water and humidity in a bathroom? Hardwood is going to look better (at a price) but does it offer better protection to the conditions? What is the best way to seal the wood given the veneer panel needs to match the solid wood?
I dont want to use mahogany (due to the colour), European oak is much closer to the colour I'm after - would it be suitable?
