Take down all the PB on the sloping part.
Insert 50mm insulation between joists.
Then re-board with insulation backed PB (30 or 40mm insulation) and long enough screws to screw into joists. 30mm insulation + 12.5mm PB, use 60-70mm screws.
Use scrim tape along edges. Fill edges and screw heads.
Where new PB meets wall and exisitng ceiling, you'll need to cut it at an angle.
Thanks but I don't really understand what you mean. You say 'take down all the PB on the sloping part' and then 'insert 50mm between joists'. But if I've taken the PB down, what's the 50mm insulation going to rest on? Or am I missing something here?
