Best dry lining boxes for lath and plaster wall
Down in Devon we have lots of older houses which have lathe and plaster on external walls, often a 2" or 4" batten on the wall, or stood from the wall. Very varying depths from wall front to stone wall behind. In these cases I have found either 47mm, 35mm or 25mm metal boxes fixed to the wall or on battens fixed to the wall in various combinations works well.
It certainly makes sense, as an alternative/prelude to cavity walls, but I have not personally seen it, other than the similar situation in relation to the wattle/daub outer that I mentioned.
Kind Regards, John
