D
Deleted member 174758
I don't think the 50mm bits are meant to be used in the holder because they have a thinner shank which is designed for use directly in the chuck of the driver. I tend to use them for tight situations where I can't get a bit, holder and impact driver in and also where I need to drive (or more often remove) screws which are/have been sunk under.
I have found with apprentices that higher levels of breakage when using my impact driver have been down to the them not keeping the bit firmly in the recess in the head of the screw to maintain contact, or in other words they aren't keeping up with the driver and are smashing the bit to pieces as a result
