On my extension i am doing a suspended floor. It is on the ground floor and i know you need insulation in there.
What is best, rigid insulation sheets or the loft type insulation suspended between a net?
I am thinking about going for the soft insulation as i thought it would be better at sealing any small gaps between the joists. Also what amount do you need between the joists on a floor ?
I am doing the work so the most cost effective method in terms of labour doesn't need to be factored in. I want the best solution to draughts and heat loss really.
