Hello,
Recently had a new shed/outbuilding built in the garden and would like the option of having two sockets and a light in there.
Shed is 6 feet from the house.
On the back wall (nearest the shed) inside the house I have 1 socket and 2 switched FCU's side by side (one feeds and outside socket which is directly through the wall and the other feeds an outside security light). All 3 outlets are on the downstairs ring (confirmed) which is RCD protected.
Ideally I'd like the option of isolating the power to the shed from inside the house but that back wall is starting to look clumsy enough already plus my young son is now in the habit of switching off the FCU's.
An (electrician) friend suggested just taking a feed from the outside socket to the shed.
Alternatively I could add another FCU inside to make it 3FCU's and a socket.
Or the final option is a run of approx 10m (would need to be underground) along the side of the house to the CU which is by the front door.
Whichever option it is the cable will be SWA suitably ran underground. My friend will (genuinely) make all the connections (I've never terminated SWA before) and I'll be the digger.
Cheers
Cheers
