Best quality white accessories
Wow, do click support that configuration? pretty outstanding I thinks, if it works and looks good then a real winner for that situation I`m thinking.
Yes, they do whats called mini-grid which works just as interchangeable switch units on the back of the plate (no yoke as with 'proper' grid)
You can either buy a 6 gang plate and the mix of 2ways and intermediates you need, or get a 6 gang switch and 2 intermediates to swap out the middle modules for, depending on whatever works cheapest
Mode is nice looking rounded white moulded, Polar is cheap looking sqaure corners, define are the fancy ones in a range of finishes
and
Thanks for the info. I will have to review them. You learn something everyday :)
Click Scolmore ............... can't remember having a failure and importantly readily available over the counter of several local suppliers
Not sure about switches, sockets etc but I like the pull switches and a positive click when you pull. As said I`d try each switch before fitting say 10 or 20 times (actually I think probably 10 was enough because they`d if they did fail then would all fail within 3 or 4 clicks). I`d buy them in boxes and then find which failed on the first few pull clicks, average about 1 per box failure rate but once they had lasted a few test pulls without jamming up they would last forever. Like that for years, they might be better now because I have not fitted one for a few years.
