Me thinks the OP will be doing this themself or have a 'plumber' from a foreign land.
Andy
Me thinks the OP have a 'plumber' from a foreign land.
Me thinks something naughty afoot.
Unless the person who will get you the 20% discount lives in your household I would be careful spanking their staff discount, it is not a mates rate discount it is solely for that staff member and is checked especially when the item price hits a certain threshold.
Ever considered I'm the SF employee, but that I just don't know a lot about boilers. I've not had much luck getting someone over, 2 out of the 8 I approached came over. Both talked a lot, but without giving me a solid recommendation. "Here's 4 folders full of boilers, let me know when you've chosen." Euh... what? When I pressed them saying: "what would you do if it was your house, but considering my parameters", they both came up with the most expensive option with solar panels etc... while I was clear it wasn't an option due to the roof.
What's your nearest town? Might be able to recommend someone to do the job for youEver considered I'm the SF employee, but that I just don't know a lot about boilers. I've not had much luck getting someone over, 2 out of the 8 I approached came over. Both talked a lot, but without giving me a solid recommendation. "Here's 4 folders full of boilers, let me know when you've chosen." Euh... what? When I pressed them saying: "what would you do if it was your house, but considering my parameters", they both came up with the most expensive option with solar panels etc... while I was clear it wasn't an option due to the roof.
@muggles who has peed you off that much ????What's your nearest town? Might be able to recommend someone to do the job for you
You should be on stage with those witty one linersFerroli, heatline capriz best on the market.
Got two guys to look at it tonight. Both suggested a combi boiler would be OK. One suggested a 38KW, the other a 30KW. Feels like there's a pretty big difference between the two.
The 38KW guy was only really interested in Valliant boilers and Eclipse thermostats. The other was (to my mind) more pragmatic, and said they're all largely the same, but steered me towards Bosch, Valliant or Viessman.
