Best way of wiring these sockets - pic included
Schukosteckdosen im 90 ° Winkel, ideal für Winkelstecker. - Ideal für Winkelstecker und Netzteile Which translates to When translated to English Sockets at a 90 ° angle, ideal for angle plug. - Ideal for Angle and Power Supplies OK I am being silly now :D thanks to Google translate.
Hmmm. Ok, so English is perhaps no good - can you perhaps translate it into JohnW2-speak? :-)
Kind Regards, John
It means that the sockets are at 90°. That would be ideal for angular plugs.
If the strip is installed vertically, the plugs go in twisted through 90° so the flex comes out of the strip horizontally.
If the plugs went in at 0° you would need a big gap between each socket so the flex from the plug above doesn't obscure the socket below.
OP, those strips look ideal, but I would avise that you fit an RCD plug to each one for some additional protection for yourself.
I will do, but what is the chances of a false RCD trip? I have no experience with RCDs at all.
If false trips are likely, then I a few none protected outlets too.
If you're only running a couple of computers per strip then the RCDs will not trip unless there's a fault, in which case you want the RCD to trip as quickly as possible.
You should not have any none RCD outlets. If you plug a faulty piece of equipment in and it trips the RCD the temptation is there to plug the equipment into a none RCD outlet, and then you get electrocuted and die.
Do I take it that you mean 'standard plugs' (with cable outlet at right angles to pins)?
If the strip is installed vertically, the plugs go in twisted through 90° so the flex comes out of the strip horizontally. If the plugs went in at 0° you would need a big gap between each socket so the flex from the plug above doesn't obscure the socket below.
It never actually occurred to me that anyone would install it vertically. However, whether it's installed vertically or horizontally, it would surely be very daft (and virtually unprecedented?) to have the sockets rotated through 90 degress from the position they're in, for the reason you give. The way they've done it seems to me to be 'the expected and obvious' orientation - and the only thing it's at 90° to is the daft method :-) ... or am I missing something?
Kind Regards, John
Perhaps it's to do with German plugs which might have the flex coming out of the back of the plug, or the side.
Ah, yes, that's probably the explanation. However, this item was obviously designed for BS1363 plugs and, as I said, to have multiple sockets the 'other way around' for such plugs would be plain daft! One therefore would not really have expected them to make that comment (virtually a 'claim'/USP!) in relation to the item in question - after all, that's why I got confused!
Kind Regards, John
... it would surely be very daft (and virtually unprecedented?) to have the sockets rotated through 90 degress from the position they're in, for the reason you give.
You are correct, it would be daft to have them turned 90˚ from where they are - but it's actually too common and makes for a p**s poor PDU in terms of plugging things in.
However, this item was obviously designed for BS1363 plugs ...
It probably isn't "designed for" our plugs, many of these types of device are "generic" in as much as they have a common extrusion with various alternative inserts they can fit. So this is "designed for" our sockets only in as far as they've fitted BS1363 socket inserts rather than Shuko or C13 or ...
Luckily, whoever designed the BS1363 insert was switched on.
EDIT: But of course, they'll have a single set of instructions/details, and so there may be stuff in there (eg the 90˚ Skuko plug someone mentioned) that doesn't make sense to us.
It probably isn't "designed for" our plugs, many of these types of device are "generic" ...
That'sprobably true, but the particular manifestation/variant of their product which they are selling in the UK is obviously 'intended' (if you prefer that word to 'designed'!) to be used with BS1363 plugs.
That's their mistake, then. At least with cars designed initially for the continental market, the variant sold in the UK with steering wheel/pedals on other side etc. comes (well, every one I've seen does!) with a RHD-specific instruction manual that recognises that it is a variant!
Kind Regards, John
I know what you are saying, but it sounds like you don't buy much electrical stuff (or even non-electrical stuff*) - even getting instructions with words in english can be a bonus for some of it :roll: Still, they've put the sockets at a reasonable angle, so it seems like a decent unit - as I've mentioned, we've some in a box at work where the sockets are inline and the cable from one plug has to work it's way round the next.
* I've another thread open regarding doors a mate has had fitted - the (so called) joiner has really f***ed them up. Found a set of instructions for the door hardware and from memory there weren't even any words - just a few small and vague diagrams.
http://de.wikipedia.org/wiki/Schuko[/QUOTE]
This was my thought as well, most continental plugs I have seen had the flex coming out the back, so for someone in Germany coping with the flex coming out the plug at 90 degrees is worth mentioning.
For us it's the norm. Don't think I've ever seen a UK plug with the flex coming out the back.
Oh, I buy a lot of all sorts of things and am more than well aware of the documentation problems (watch this space!). However, as I'm sure you'll agree, common does not mean 'right'. Of course, in some walks of life, instructions/documentation are regulated, as well as products.
I agree totally. As you realise, my initial confusion arose because I was looking at a product made 'as I would expect/hope', but with documentation that seemed to be making an issue about this!
Kind Regards, John
