The room stat should be in a room where the rad does not have a TRV, generally a hall. Neither TRV nor room stat settings are terribly accurate. The above is not ideal.
Have a look at question 6 in the FAQ here - If you convert your 65/75 units, what's the kWh usage? Or tell us if you meter is displaying Cubic Feet or Cubic Meters?
I can't imagine the loft insulation halving our gas bills though, so assuming there isn't anything seriously wrong with the boiler etc. (I'll find out in a few days when the plumber comes over), I'm stumped really as to why our usage is so high?
Have you calculated your whole house heat loss (See here) yet??? - Once you do that, you (we) can more easily identify where the heat loss / gas usage is!! - Changing the figures in that calculator will also tell you how much difference loft insulation, cavity wall insulation etc will make!
