Best way to wire surround sound + best cable?
yes its ok to chisel. TBH, i dread to think who thought of using thermalite to build walls, never mind actually support buildings. :eek:
go very steady with thermalite or you will end up going through. ;)
plastic blanking plates are unfortunately quite brittle
taking it slow on a drill press with a block of wood underneath is probablly the best way but i haven't tried it myself.
should be easy enough to drill then, brass is a pretty soft metal easiest way for a diyer would probablly be to screw the plate face down to a block of scrap wood, made dents with a puch to guide the drill and then drill it with a normal hand held drill and a HSS bit.
since the plate is metal make sure whatever sockets you buy have built in plastic peices to isolate them from the plate they are mounted on.
