BG 330+ with F22 Dry error
12 Feb 2007
Kent
Noticed today we have no hot water. Condensing boiler showing F22 dry error. No obvious hose for refilling water in and cannot see how to get current pressure displayed.
Reset boiler and it did work for 30 seconds before displaying error again.
We did have a power cut yesterday.
BG are booked for Tuesday, however is there anything I can try in meantime pls? Thank you.
Your boiler is made by Glowworm for BG and is mostly based on their GlowWorm Flexicom HX with maybe some influences from a GlowWorm Ultracom Sxi.
You may get some clues from the manuals of those Glowworm boilers.
But probably better to wait until Tuesday.
Refilling if a pressurised boiler, as most now are, is a regular requirement and you should get the engineer to explain to you how to do that. That may be all that is needed.
