yeah i see what you mean... i cant be having much deflection hanging doors off it....!
I hear leotards taste good with a dollop of ice cream!
Most sliding/folding doors nowadays are supported by bottom rollers, with just guide wheels in the top track
I have this exact situation, and I have been looking at this diagram and wondering how this buildup prevents condensation on the beam shelf? The steel is both outside and inside the thermal envelope and there's no insulation either side, and the shelf is thick enough to conduct a high level of heat. Since in our case it's in the kitchen, there's likely to be high humidity.Nobody's being funny, its a UB with a shelf angle, you cannot buy them off the shelf, any engineer will know what you are talking about.
The techys at Catnic will spec a lintel for you in only a standard situation, hanging a bi-fold off a lintel is not standard in the eyes of your average Catnic or IG techy.
Thanks for the help Steve, that poses the question of how to attach the window straps, would they be OK on the "cold side". Also the joists have to be supported by the beam and it's a warm roof so they would be touching the cold beam. Would there be a problem with condensation getting through to the beam and making everything rot?Could you fit some insulated plasterboard on the inside under the beam?
sliding doors are bottom hunged agreed but bi-fold doors are top hung. bi-fold doors are a lot heavier than sliding. being top hung makes them a lot easier/smoother to open/close.
i've had 2 installed - a 12 and 6 ft.
