Biasi 24S dhw fault
Tony,
Thanks for the reply, I'm assuming you have a Biasi spares or service manual? In the spares manual the part I think you are referring to is
Part No. BI1011 107 (O-ring for large plug) or is it BI1011 502 ?(smaller plug assembly).
I tend to think you're referring to the large O-ring, but thought It best to clarify.
1. Switch in good working order, no signs of damage.
2. Leak is best described as a steady trickle.
Incidentally, can I get it from you?
Thanks for your continued patience,
Andy
Yes, but its a gland not an "O" ring.
From memory it might be 103 on the drawing?
Commonly available because so few clean the system.
Tony
Tony,
Thanks for everything, part arrived, fitted and I am happy hearing my 5yr old daughter playing in a lovely warm bath again. :)
Aah the simple things in life.
Thanks again. :D
