Hi my prv seems to be leaking at about 2.7 bar so i am looking at replacing it.is it something a novice can do? i think i just need to drain the boiler usung the prv then unscrew and replace or is there more to it than that ....
hi dave
the company that fit my radiators set the pressure at 1.5 cold and told me to keep it at that but when rads are on it rises to aprox 2.8-2.9 is this not right then? do you think i should drop pressure to 1 bar cold?
also sorry to sound thick but what is the f and r and how would i isolate.
thanks
