yeh prv can sometimes stick or block therefore is the reason why engineers servicing sealed system appliances should activate them manually to confirm correct operation! it's just the fact that they can then fail and need replacing as to why many engineers dont test it, cos you've then got the old saying of """my boiler was working fine till you touched it"""" lol! one thing to be weary of is the pipe connecting the expansion vessel can block and cause the same problems as an under or over pressurised vessel even though the vessel itself has correct pressure, time will tell though!!!!! hope its ok for you
