Dan_Robinson said:Talking of cheap shltty boilers, you should have had a call today about a Glowworm...
Agile said:I find it a little disrespectful calling a Biasi a "cheap boiler".
They are very good boilers but sold fairly cheaply. ( Thats different! )
The did get something of a questionable reputation because they were bought by people who wanted to get them badly installed by non-registered people.
That was totally unfair because it was not the boiler's fault if the system was not cleaned properly.
The most important feature is how its installed and particularly if the system it totally clean and the gas pipe correctly sized.
They are now one of the most reliable boilers when correctly installed and in the last few years they have had no significant reliability problems unlike Vaillant ( diverter valves and then seals ) or Viessmann ( PCBs ).
More an more installers are now realising that they are a good boiler but a reputation is hard to shake off quickly.
kerryf said:Thanks Dan, I appreiciate your reply. I would love to buy a nice expensive piece of kit, however at the moment funds will not allow and I need some hot water.
Dan_Robinson said:We would cover Stevenage, but...cheap is not something I do I'm afraid. Our InterCombi list price (with flue, "make my life easier" bracket and delivery) is £954.35+VAT although there is a little movement on that.
But then there are naff all spare parts to buy compared to most of these other cheap and nasty things. So future maintenace costs are going to be much lower - no diverter, no diaphrams, no PHE or thin waterways etc.
Just a pump, fan, 3 temp sensors, gas valve, flow switch, spark generator pcb, burner, EV (at the front that swings out easily).
The Riva advance - tonnes more, IMHO these boilers are sold cheap so that the spares can be milked for all their worth.
Doctor Drivel said:Don't buy a boiler with secondary condensing heat exchanger, sometimes referred to as a recouperator. Buy one with a one piece heat exchanger. I think all BIASI's have recouperators - others may clarify this.
Agile said:Doctor Drivel said:Don't buy a boiler with secondary condensing heat exchanger, sometimes referred to as a recouperator. Buy one with a one piece heat exchanger. I think all BIASI's have recouperators - others may clarify this.
The Biasi does have the M96 band B model with a recouperator. However this is a totally stainless steel unit and does not give any problems at all. Its one of the very few band Bs to have this!
The latest Biasi is the band A M110 premix. This is very similar to most of the other manufacturers although it does have external weather compensation and comes with a two year guarantee. Currently it still has brass water sections and the full stainless gianonni heat exchanger.
Agile said:The Biasi does have the M96 band B model with a recouperator. However this is a totally stainless steel unit and does not give any problems at all. Its one of the very few band Bs to have this!
