- Joined
- 22 Oct 2015
- Messages
- 1
- Reaction score
- 1
- Country
Hi.
I'm hoping that someone may be able to assist me with an intermittent fault on my boiler. When I say intermittent, the fault will occur every day if I try to use the boiler as intended & the fault has been present for at least three years. The fault has saved me a fortune in gas over the years but my ever understanding wife is becoming less so!
Here's the deal:
Any assistance would be greatly appreciated; especially by the Mrs! Until then, I'll just keep burning logs! Thanks in advance.
Here's the deal:
- The fault occurs both in DHW & C/H mode
- The ignition sequence fails but only when at temperature.
- If I get in the shower in the morning, I could have a 1 hour hot shower without any problems but once I turned the water off the next person would be very annoyed as the boiler would not reignite (unless they left it for 30 minutes or so).
- When the fault occurs, The fan & pump will run until it has decided that sequence will not complete and then the diagnostic lights display constant red central light & simultaneously flashing green's on either side.
- The boiler does not lock out.
- Likewise when calling for DHW, the boiler will bring the system up to temperature but once the system needs to start cycling, it fails to ignite again.
- The fault never occurs from cold, only when at temperature.
