Got some 3m bifolds coming and was wondering what is suitable to span above. I have some 8x2 laying about,,, would there be much difference in doubling them up vs alternatively using 6x2 flitch beam. Not fussed either way, just want to get it right for the doors TIA
4x2 studs, 3m high max build and got Planning permission. Height isn't an issue other than if I put in 8x2 as lintel they will be higher than the wall plate and because the roof joists are running from side to side rather than to the front, it would make my overhang slightly difficult
Even though the title says garden room? I'm not complaining about lack of responses, actually taking the **** out of my self for asking what I assumed was a silly question!!
Yes true. So my 3 walls are currently sat with a wall plate 2300mm high, 8x2 joists on top, overhanging sides and 8x2 laddering for overhang at rear. Bifolds are 2125 with 18mm flooring, so give or take 2145mm, if I put the 8x2's doubled up above the doors with a bit of extra wriggle room, I've only got around 140mm to top of wall plates, so the 8x2s will be above by around 50mm. How would you go about adding the front overhang? Notch out the small 8x2 overhang timbers? TIA
Over hang won't be huge, maybe 300mm from front edge. Apologies but confused about shaving 5mm off as door lintel will be above top of wall plates by around 50mm.
Ive got my last roof joist inside of what will be my end studs for the front wall, so set back 90mm from front edge. At the back I've done the same and then rested ends of overhangs on top of back wall plate and screwed to last roof joist. This time and if putting in the 8x2s as a lintel, that 3m+ section will be 50mm higher than the side cheeks (as they can be set the same as side wall plates)
